after import apache logs via scipt import_logs.py, no statistics are displayed on the portal piwik
after checking the logs are loaded into the database
the user who wants to view the logs on the portal administration rights
why it does not work ?
I also have an error message in apache logs : ALERT - script tried to increase memory_limit to 134217728 bytes which is above the allowed value
how to change the limit?
what configuration file is it?
another question: what is the name the file that allows you to modify the rights of the super utiliateur ?
impossible to do via the portal (API)
thank you for your help
