Is there a way to disallow Matomo users to login to Matomo (3.5.1) when using LoginLdap 4.0.5?
Thanks,
Khalil
Thanks,
Khalil
Are you not able to remove the user/s from their Matomo defined Ldap group?
In case you have not yet found support:
Hi
I successfully installed LoginLdap 4.05 and Ldap user can login without any issue.
What I am looking for is to disallow Maotmo users to login to Matomo (only LDAP users should be able to login to Matomo).
by the way the link you sent me is not working
Thks in advance
Khalil
Don’t know if it works, but have you tried:
Settings -> System -> Users
Choose “Apply for all websites in dropdown”
Set it to “no access”
