disableCookies does not work
#1
I tried to stop piwik from setting cookies.
I followed this instruction: How do I disable all cookies for a visitor? - Analytics Platform - Matomo
But still some cookies are set: _pk_cvar, _pk_id, _pk_ref and _pk_ses
I do use Piwik 2.10.0
This is my trackingcode:
<!-- Piwik -->
  var _paq = _paq || [];
  _paq.push(['disableCookies']);
  _paq.push(['trackPageView']);
  (function() {
    var u="//www.sven-lewerentz.de/piwik/";
    _paq.push(['setSiteId', 1]);
</script>
<noscript><p><img src="//www.sven-lewerentz.de/piwik/piwik.php?idsite=1" style="border:0;" alt="" /></p></noscript>
<!-- End Piwik Code -->
Any idea why it is not working? Thanks in advance!
Sven
(Matthieu Napoli) #2
Are you sure these are not “leftovers” from the previous configuration?
If you delete those cookies, do they reappear?
#3
Hi Matthieu,
yes, I deleted the Cookies (in Chrome) and after a reload they were set again. I checked it on a second computer, too.
Sven
#4
I just created a completely new website and added the code as described in the FAQ
Fresh Install, different domain, Piwik 2.11.2 no old cookies set.
And again the same problem: Cookies were set by Piwik on first visit.
Anyone here who successfully uses “disableCookies”? I try to figure out, if this is caused by a mistake I made or if this is a general bug…
Thanks!
Sven
#5
Did you try in Firefox and in Chrome.
To my experience, it works fine in Firefox, but doesn’t work in chrome.
I know this is very strange but I have been etsted for hours and I couldn’t find any fix to stop installation of visitors cookies in Chrome (cookies are ses / id / cvar…)
Agnès
#6
Hi Agnès,
thanks for your reply. Yes, I tested in Chrome only.
I will check Firefox and IE tomorrow.
Sven
(Matthieu Napoli) #7
If you it does work in Firefox and not in Chrome please open an issue on Github so that the team can fix it: Sign in to GitHub · GitHub
#8
I can confirm, that it works fine in Firefox, but not in Chrome.
It seems to work in IE11, too. (But I can’t guarentee this, because I am confused by the way cookies are displayed in this browser)
I will open an issue on github.
Thanks @all
Sven
#9
I already opened a ticket for this : The pragma "disableCookies" does not work in some browers · Issue #7494 · matomo-org/piwik · GitHub
Please feel fre to confirm it by adding your experience
