We set up Matomo on one of our client’s website to be fully GDPR compliant. I guess all visitors are tracked through the first party cookie (but anonymized) even if they dont give their consent for cookies?
The client uses mtm tags to track his campaigns. For the last campaign he did, for a determined period, Matomo displays 15k visits, but the communication agency they work with send them a report with 118k clicks on this campaign.
How is it possible to get this difference? We have the same issue with a different client.
Can you confirm me all visitors are tracked via the first party cookie, even if the visitor refuses third party cookie?
We can’t assess that without looking at your implementation. That depends on your consent manager (if it loads the tracking code before consenting). Tracking can also be done without cookies at all, so it doesn’t rely on cookies (but then, you can’t recognize visitors cross session).
There are a lot of possible explanations. Remotely, we can’t tell, what’s happening. Possible reasons:
A lot of bot traffic (that matomo doesn’t count)
Incorrect campaign tagging
Slow loading of Tracking code (visitor bounces before being tracked)
Slow page loading time (visitor bounces before page gets even loaded)
Incorrect integration with the consent management
Other tracking / integration errors
“Phantasy” numbers by the publisher / agency, including automated queries, double clicks, monitoring, etc. They love to overreport clicks.
That shouldn’t be an issue at all, because even without any cookie, visitors can be tracked.
How does the consent mode work by default? Before or after? I found the doc to set it up on Klaro but we won’t need to set it up if it loads before consenting by default.
You mean if a visitor has disabled all cookie he will still be tracked? Through the .js then?
There is no default consent mode. A visitor is tracked by default, as soon, as the tracking code is loaded.
Only if a) the consent manager blocks the loading of the tracking code or b) the tracking code contains the call “require(Cookie)Consent” before “trackPageView”, tracking / setting of cookies is prohibited.
If you’re using the TagManager, you can configure these settings in the UI.
Yes. The cookie is not a tracking mechanism. It’s only there for visitor recognition and storing cross session / cross domain visitor ID info (and possibly other info).
