Hi there!
I’m kind of confused.
I use both Inspectlet and Matomo on my site.
Code for both of these are in a javascript file that also contains jquery and more so it’s quite heavy. I defer load this js-file with the Google recomended way like so:
function downloadJSAtOnload() {
var element = document.createElement("script");
element.src = "<?php bloginfo('template_directory'); ?>/defer.js";
document.body.appendChild(element);
if (window.addEventListener)
window.addEventListener("load", downloadJSAtOnload, false);
else if (window.attachEvent)
window.attachEvent("onload", downloadJSAtOnload);
else window.onload = downloadJSAtOnload;
</script>
My problem is that my statisitcs doesn’t seem to be correct in Matomo.
Some visits are reported as 1 sec in Matomo but in Inspectlet they are complete sessions with visits to subpages and all. I do see this because they are connected to a “campaign” variable in a specific mail.
Any idea as to why this is happening?
Is it not a good solution to use the Matomo code in a defered loaded file?
As I mentioned it’s quite heavy - 150kB or so so it take some time to load…
Best, Niklas
