Dashboard Won't Load!
(fiction) #1
I installed the software and everything seemed to go fine. However, my dashboard will never load, even after reinstalling. All the other links seem to work okay but the dashboard hangs on “loading data” every time.
How do I fix this?
(fiction) #2
[quote=fiction @ Aug 24 2009, 03:54 PM]I installed the software and everything seemed to go fine. However, my dashboard will never load, even after reinstalling. All the other links seem to work okay but the dashboard hangs on “loading data” every time.
How do I fix this?[/quote]
No one has ever had this problem?
(vipsoft) #3
See fix in http://dev.piwik.org/trac/changeset/1442
