After updated Piwik today, my dashboard will not load with Firefox, it loads fine with IE. I’ve tested on 2 machines, same results. I can click the links, but clicking on the sites dropdown, or the calendar does nothing as well. What is causing this? I’ve attached a screenshot of what I see using firefox, all my boxes are missing.
I’ve deleted everything completely and re-installed and still have the same results with Firefox.
No, It’s not triggering any errors. I can go to visitors, Actions, Referrers, and Goals, and it all displays, except the website dropdown and calendar does nothing when I click on it. The dashboard will not display any of the blocks at all.
When I click the dashboard link, the widget’s & dashboard menu is showing under the calendar, but when I refresh the page, it disappears. I’ve attached a screenshot.
Probably not a php memory issue since it works in chrome… Not sure, can you PM the Piwik URL login password and bug description and this Post url ? thanks (or email matt att piwik.org )
On the site you have sent me I see Cloudflare is injecting some javascript in piwik. This javascript is causing Firefox to fail with Piwik. Please contact Cloudflare developers to notify them that their Javascript breaks Piwik dashboard! Thanks
After upgrade from 1.9.2 to 10.1.1, Piwik not works with IE
I get a javascript error:
Agent utilisateur : Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; .NET4.0E)
Horodateur : Wed, 16 Jan 2013 08:07:00 UTC
Message : Identificateur, chaîne ou nombre attendu
Ligne : 1029
Caractère : 95
Code : 0
URI : http://srvpwk.intranet.chuv/piwik/index.php?module=Proxy&action=getJs&cb=d38f5db8a827807e095fe14dc86d69f7
