Hello all. After manual updating to 3.8.1 this morning, the dashboard no longer shows up properly. I can login, but only see text. Not sure what happened. The dashboard does not show properly in any browsers.
It seems like JS and CSS doesn’t load. Often this is because of adblockers, but that is unlikely in your case.
If you open your browsers developer tools (F12) you should see the exact reason.
One solution that could help in multiple cases would be deleting everything in the tmp/
directory, which causes Matomo to regenerate these files.
Deleting the tmp folder was the magic Lukas! All is good again. You guys rock!!!
Thanks!
