The layout of the dashbaord is way too narrow to use. There is a CSS rule on the body tag for 390px max-width. Is this a bug? Did our sys-admin install a mobile version by accident? Is there a way to turn this off if you are not using a mobile device? Some of our users do use a mobile device so there ought to be a choice. Searching this site revealed no solution to this problem or mention of it as a bug. Thank you.
It looks like the dashboard was narrow because one of the widgets was having an error. This seems pretty user-unfriendly to make the layout so narrow when a widget is having an error.
This bug was fixed in latest version
