Hello all,
I have been searching the docs for a while now and finally decided to ask here at the forum, because my search was not successfull.
I know it is possible to create plugins in oder to realize widgets showing a custom subset of data in a specific way. But…
It is possble to use the API to tailor data shown by a already exsisting. For Example change
index.php?module=Widgetize&action=iframe&columns[]=nb_visits&moduleToWidgetize=VisitsSummary&actionToWidgetize=getEvolutionGraph&idSite=1&period=year&date=2012-06-06&disableLink=1&widget=1
to
index.php?module=Widgetize&action=iframe&columns[]=nb_visits&moduleToWidgetize=VisitsSummary&actionToWidgetize=getEvolutionGraph&idSite=1&period=year&date=2012-06-06&disableLink=1&widget=1&segment=browserName==FF
By adding the “segment” param the widget shows a subset of data.
Is there any way to ‘save’ this customized widget calls for reuse on a dashboard?
If it is not possible yet, are there any plans to create a possiblity like this in the future?
TIA
Best Regards
