Custom Reports with more than 3 dimensions
Hello folks,
I have just started with custom report plugin for report, while diving into it I found we can only set 3 dimensions per report but I need more dimensions for more detailed report. I’m looking for configuration to set more dimensions to be able to use for custom reports.
Any help will be appreciated.
Kind regards,
Shailesh P.
Hi @Shailesh_Patil
As this concerns Custom Reports premium plugin, you can ask directly your question by email to the support team.
Hi @heurteph-ei,
Yes I have reached out with the support team after I created this post, they are also said it’s limited to 3 dimensions. It will be good if there will be provision to add more like custom dimensions for on-premise userbase.
thanks & regards,
Shailesh P.
Hi @Shailesh_Patil ,
Yes, currently there is a limitation of 3 dimensions in Custom reports, however we have an internal ticket regarding this. Can not give an ETA the moment.
Hi @karthik ,
Thanks for the update, looking forward to see it in future updates.
thanks & regards,
Shailesh P.
6 months later, still the same status.
Hi @Hurricane_x. We’ve already submitted your request to our development team. However, it’s not currently on our immediate roadmap. While we don’t have a timeline for when it may be prioritized, we’ll certainly keep it under consideration as we evaluate future releases.
On the other hand, you can create an additional custom report for the dimension you desire. Once created, you can use the Report page feature of Custom report so you can make the new report as a Report subcategory. With this feature, you’ll be able to combine 2 custom reports into 1 report.
