Hello everybody,
I believe my custom optout is not working.
I use Wordpress 5.5.3 wit the plugin ‘WP-Matomo 1.0.23’. The external Matomo instance is on 3.14.1.
I have followed this tutorial https://developer.matomo.org/guides/tracking-javascript-guide#optional-creating-a-custom-opt-out-form
My tracking code now looks like this:
_paq.push(["disableCookies"]);
_paq.push(['trackPageView']);
(function() {
var u="https://MATOMOURL/";
_paq.push(['setSiteId', 'SITEID']);
g.type='text/javascript'; g.async=true; g.src=u+'matomo.js'; s.parentNode.insertBefore(g,s);
document.addEventListener("DOMContentLoaded", function(event) {
function setOptOutText(element) {
_paq.push([function() {
element.checked = !this.isUserOptedOut();
if (document.querySelector('#matomo-opt-out-label') != null){
document.querySelector('#matomo-opt-out-label').innerHTML = this.isUserOptedOut() ? 'You are currently opted out. Click here to opt in.' : 'You are currently opted in. Click here to opt out.';
var optOut = document.getElementById("optout");
optOut.addEventListener("click", function() {
if (this.checked) {
_paq.push(['forgetUserOptOut']);
} else {
_paq.push(['optUserOut']);
setOptOutText(optOut);
</script>
The problem is now the following:
When I load the page with the custom optout-form the checkbox is always active.
If I deactivate it and reload the page, the checkbox is active again.
The ‘piwik_ignore’ cookie is never set.
For testing purposes I also implemented the iFrame variant.
If I deactivate the checkbox in the custom form and reload the page both checkboxes are active (iFrame and custom form)
Furthermore I noticed that sometimes you have to click twice to activate the checkbox.
Did anyone else observe this behaviour or do I get the whole thing wrong?
