Custom dimensions settings
I like to set custom dimensions and need help in the start.
An example:
_paq.push([‘setCustomDimension’, customDimensionId = 9, customDimensionValue = ‘{{Page Hostname}}’]);
What will do actually number 9?
9 is the number of the custom dimension you created in the custom dimensions settings in Matomo
I have installed the custom dimension plugin. Is there any good example how it is seen in real statistics?
When searching I noticed one example but how to know real statistics values in advance?
  var _paq = _paq || [];
 /*Source: https://req.co/blog/google-tag-manager-gtm-and-matomo*/
  _paq.push(["setDocumentTitle", document.domain + "/" + document.title]);
  _paq.push(["setCookieDomain", "*.mydomain.com"]);
  _paq.push(["setDomains", ["*.mydomain.com"]]);
  _paq.push(["enableCrossDomainLinking"]);
  _paq.push(['enableHeartBeatTimer']);
  _paq.push(['trackVisibleContentImpressions']);
  _paq.push(['setCustomDimension', customDimensionId = 9, customDimensionValue = '{{Page Hostname}}']);
  _paq.push(['trackPageView']);
  (function() {
    var u="//myinstance.innocraft.cloud/";
    _paq.push(['setSiteId', '{{Lookup - Hostname to MA SiteID}}']);
</script>
If I like to pull out Full name from input fields, how to do this using Custom dimensions plugin?
Can you reply if I like to get Full name how to do in practice?*
