I am seeing the following error several times on the Admin page:
curl_exec: SSL: invalid CA certificate #1 (offset 0) in bundle. Hostname requested was: plugins.piwik.org
I understand this is an SSL error but with the plugins domain?
I am also getting this error when I attempt to upgrade. The upgrade reports “failed” but proceeds anyway (and seems to work fine).
Any ideas?
gfive
February 16, 2017, 2:45pm
#3
I get the same problem, also running Mac OS X 10.11
sbnoble
February 21, 2017, 3:38pm
#4
Same under 10.11.6 Server.
FWIW, running “curl https://plugins.piwik.org/ ” on the command line works without error, so perhaps this has something to do with the PHP curl_exec function.
gfive
February 28, 2017, 9:44am
#5
@sbnoble , same here…
Marketplace = curl_exec: SSL: invalid CA certificate #1 (offset 0) in bundle. Hostname requested was: plugins.piwik.org
Plugin install = curl_exec: SSL: invalid CA certificate #1 (offset 0) in bundle. Hostname requested was: plugins.piwik.org
main screen administration = curl_exec: SSL: invalid CA certificate #1 (offset 0) in bundle. Hostname requested was: plugins.piwik.org
Checked with: SSL Server Test (Powered by Qualys SSL Labs) and got an A. chain and all are ok. So maybe it’s not us but Piwik.
Checked curl -v https://plugins.piwik.org and curl -v https://mydomain Both are ok. So I starting to think that curl in my php is not right or broken… will try a php upgrade
Piwik version: 3.0.1
MySQL version: 5.5.5
PHP version: 5.6.24 (tried newer version 5.6.30 and php7)
gfive
February 28, 2017, 4:04pm
#6
Yes!!! Found the solution.
$ php -i | grep “SSL Version”
I suspect you’ll see this:
SSL Version => SecureTransport
And that’s the problem. OS X is using SecureTransport and NOT OpenSSL.
Simple solution: php - Curl POST to HTTPS url gives SSLRead() error - Stack Overflow
So or you have to follow those steps (not complicated If you do a bit more with your osx) or Piwik has to add SecureTransport.
Many thanks gfive for this solution.
I don’t know if this is also the problem that affects https tracking. My Piwik is able to track only http pages. Can you give me feedback on this?
Thanks
I’m also on Mac OS X, 10.11
sean
May 23, 2017, 3:06pm
#9
I saw the same updating from 2 to 3, but dismissed it as a quirk of a major upgrade.
I’m seeing it again now trying to update from 3.0.3 to 3.0.4. I’m also on Mac OS X 10.11.6 using Server.app and their built-in PHP, cURL, etc.
curl -v https://builds.piwik.org
reports no cert problems.
Both: php -i | grep “SSL Version” and curl -V report using SecureTransport.
Is this a piwik bug or OS bug or…?
Thanks.
sean
May 24, 2017, 2:27pm
#10
I’ve just found there is bug report open for this issue:
opened 07:20PM - 02 Mar 17 UTC
Enhancement
The PHP package bundled with Apple's Server.app uses SecureTransport, not OpenSS… L. This causes multiple errors on Mac OS X. Is there planned support for SecureTransport?
https://forum.piwik.org/t/curl-exec-ssl-invalid-ca-certificate-1-offset-0-in-bundle/22561
