Croydon
1
iframe from piwik does not show up when empedded on a different domain since update to 2.6
Tried with 2.7 b1 and still doesn’t work.
checked the response headers from the piwik iframe and it says:
x-frame-options: sameorigin
May it be that the following is missing?
<?php
header('X-Frame-Options: GOFORIT');
Thanks
Croydon
2
I don’t know if this is a new feature added, but after looking at the source code I found out what you have to do to make the iframe working again.
In the config.ini.php I set
[General]
enable_framed_settings = 1
enable_framed_pages = 1
and now the opt-out iframe shows again on all the websites.
Was this newly added? If yes, maybe the opt-out frame should be excluded from this rule or the default setting of above values shouldn’t be 0?
Thanks.
matthieu
(Matthieu Aubry)
3
Croydon
4
Okay thank you. Didn’t find that ![:frowning: :frowning:](https://forum.piwik.org/images/emoji/twitter/frowning.png?v=5)
