we have changed from the core Matomo Tag to MTM lately and I am a bit confused with the Cross Domain Linking and where to define it now.
We have multiple (country) domain sites, like xyz.com
, xyz.it
, xyz.de
etc. and I would like to track a Visitor through all of these domains. All these domains are set independently in Matomo with their own site ID’s but I would like to follow the customers journey throughout the sites. At this stage I can see the visitor coming to xyz.com
, then I can “guess” it is the same visitor on xyz.it
by checking the Place/timing…
That leads me to my question:
Where would I set these domains up, as I now have two places in Matomo to configure this.
- I would go to Administration → Manage Measurables →
xyz.com
(edit)
here I edit the URL Alias to includexyz.it
- Go to Tag Manager Container for
xyz.com
→ Variables → Matomo Configuration
here I enable “Enable Cross Domain Linking”
I would guess I do not need to include xyz.it
in this configuration under “Domains” unless I do not want the Visitor Log to show it as an Outlink.
Do I also now need to do the reverse as well, ie. In the Site Management of xyz.it
include xyz.com
As we are also using the “Conversion Exports” Add On it will make a difference in the conversion rate as currently the visitor comes to xyz.com
through a Google Campaign and then selects Italian and moves to xyz.it
and now makes a purchase, it will not be attributed to the Google Campaign anymore as on xyz.it
the visitor currently has a different visitor ID.
Thanks for your help.
