Hey guys, I’m having a problem with a Matomo instance that is implemented on a domain and two subdomains:
3 goals are on the maindomain and 1 goal each on a subdomain. All goals on the maindomain get tracked, but not the goals on the subdomains, and the visitor-log doesn’t show me any movement from the maindomain to the subdomain, so I figure, that it is not implemented properly. I implemented the tracking code and activated cross domain linking but it somehow doesnt track the goals and the traffic on the subdomains. I want to to measure everything in one Matomo instance. This is the tracking code that I implemented:
<!-- Matomo -->
var _paq = window._paq || [];
_paq.push(["setDocumentTitle", document.domain + "/" + document.title]);
_paq.push(["setCookieDomain", "*.sosafe.de"]);
_paq.push(["setDomains", ["*.sosafe.de","*.sosafe-awareness.com"]]);
_paq.push(["enableCrossDomainLinking"]);
_paq.push(['trackPageView']);
(function() {
var u="//analytics.sosafe.de/";
g.type='text/javascript'; g.async=true; g.defer=true; g.src=u+'matomo.js'; s.parentNode.insertBefore(g,s);
</script>
<!-- End Matomo Code -->```
