Hi everyone,
Unfortunately my host does not allow the execution of shell scripts on my server. Is there any way to get the cronjob done anyways (e.g. perl script)?
Thanks for any help
Hi everyone,
Thanks for any help
If you do not have a high activity website you can safely avoid using the archiving script.
If you absolutely need it, you will have to write a feature request.
I’m having the same problem. My host has a 100MB RAM limit on crons, so I switched processing on page requests on. But currently the last two days are showing 0, probably because they’re not being processed.
It would be great to have some kind of in-browser batch processing.
