Hi All
I am having an error running when running the cron to get reports emailed.
My email reports stopped when I upgraded to 2.4
I have the correct path /usr/bin/php-cli /home/myusername/public_html/mysite/console core:archive – url=http://myinstallofpiwik.com/
This is what I get in my email error message
[RuntimeException]
Too many arguments.
core:archive [–url="…"] [–force-all-websites] [–force-all-periods[="…"]] [–force-timeout-for-periods[="…"]] [–skip-idsites[="…"]] [–force-idsites[="…"]] [–force-periods[="…"]] [–force-date-last-n="…"] [–force-date-range[="…"]] [–concurrent-requests-per-website[="…"]] [–disable-scheduled-tasks] [–accept-invalid-ssl-certificate] [–xhprof]
Any help or ideas would be appreciated
Many thanks
Mac
matthieu
(Matthieu Aubry)
July 16, 2014, 10:53pm
2
remove the space between – and url and it should work
Hi Matt
Thank you for your reply.
I have removed the spaces as recommended this is my new cron
/usr/bin/php-cli /home/myusername/public_html/mysite/console core:archive–url=http://myinstallofpiwik.com/
My error message has now changed to the one listed below
[InvalidArgumentException]
There are no commands defined in the “core:archive–url=http” namespace.
Did you mean this?
core
Matt - if you have a minute to point me in the right direction it would be greatly appreciated.
Many thanks
Mac
Hi
my cron is now running I recreated a space after core:archive as in the example below which solved the cron issue
/usr/bin/php-cli /home/myusername/public_html/mysite/console core:archive --url=http://myinstallofpiwik.com/
So anyone with a similar problem ensure there is no space between the – and url
Mac
Nvizn
October 29, 2014, 8:31pm
5
I have a similar error. syntax:
su user -c "usr/bin/php /my/location/piwik/console core:archive --url=https://mywebsite.com/"
Error:
There are no commands defined in the "core" namespace.
Any insight into this error?
m01
February 26, 2015, 5:55am
6
Hello, I am receiving this error as well. How do we install the core:archive library? I am using Ubuntu.,
There are no commands defined in the “core” namespace.
/usr/bin/php5 /var/www/html/console core:archive --url=http://myinstallofpiwik.com/
matthieu
(Matthieu Aubry)
February 26, 2015, 9:57pm
7
Hi guys
Thanks for the report. can you please create a bug report in the tracker: Issues · matomo-org/piwik · GitHub and we will investigate. It works fine for most users but not for you, so we must fix it!
