Hi all,
I’m experiencing some issues on running CRON for Matomo.
I’m running two setups. One in a Compute Engine in Google Cloud with Debia Linux.
Other is running Ubuntu via Kamatera.
Both setups can’t seem to CRON properly.
However, the ubuntu setup is logging that CRON should work fine:
I’ve already disabled Browser archiving within the system settings.
Further I’ve included the following in /etc/cron.d/matomo.archive:
5 * * * * /usr/bin/php /var/www/matomo/console core:archive --url=https://matomo.refyne.dk > /dev/null
I’ve also tested (with correct populated data) from the documentation:
MAILTO="your@example.com"
5 * * * * www-data /usr/bin/php /var/www/matomo/console core:archive --url=https://analytics.example.com > /dev/null
Neither works and fetches data.
If I don’t manually test the CRON it won’t render reports anymore within the interface.
I’ve tried sudo apt-get install cron etc, but nothing really seems to work.
Anyone else experiencing this problem and managed to fix it?
