Hello everyone,
How can I create a variable that gives me the value that can be found under “data-trackinglabel”?
Here is an example:
Can you please help me with this?
Hello everyone,
Here is an example:
By installing this plugin : https://plugins.matomo.org/TagManagerExtended
You will be able to create a variable for read data-* html parameters using a new kind of variable.
Regards,
Ronan HELLO
Hi Ronan,
Thank you for your answer .
I work with the Matomo Cloud version. The plugin is not included there, right?
Is there a way to use it anyway? Or to create a variable for read data-* html parameters?
Regards,
Tobias
