A little different but here goes, we use CookieBot to control consent across a series of websites, I know Matomo has a feature built in for this, but for consistency we want to use one tool.
As such I need to add some code to the header of my self hosted instance of Matomo, but am struggling to find an appropriate matomo file to add the header information.
The Matomo consent feature allows you to use your own consent tool, which needs to tell Matomo the status on page load and Matomo will act accordingly.
Thanks for the reply, that is not quite what I am looking for, perhaps I can explain better.
The matomo tracking code needs to be installed on a website, somewhere in the header, where would I insert similar code into the matomo code, so the third party consent popup appears when a user browses my self hosted instance of matomo.
