I’m trying to fix error private directories are accessible.
Using this guide https://matomo.org/faq/troubleshooting/how-do-i-fix-the-error-private-directories-are-accessible/?mtm_campaign=Matomo_App&mtm_source=Matomo_App_OnPremise&mtm_medium=App.Installation.systemCheckPage
Using ssh Linux Ubuntu Server in the Matomo directory I put ./console core:create-security-files
But it says - ./console: Permission denied
How to fix the error private directories are accessible?
Hi @WebRanger1
You have to login (via SSH) with another user or change the user while running the console.
agent3w
(Joffrey)
February 3, 2025, 8:55am
3
Hello, this is an old topic, but I recently encountered the same error message. In my case, adding php before the command solved the issue:
php ./console core:create-security-files
