Using Piwik 2.4.0-b5 and running a cron job in cPanel to auto archive as per the instructions in the Piwik docs section.
This is the job…
/usr/local/bin/php -f /home/user/public_html/analytics/console core:archive --url=http://www.analytics.domain.com/ > /home/user/public_html/analytics/piwik-archive-output.log
I get this in the piwik-archive-output.log
Warning: Unexpected character in input: '\' (ASCII=92) state=1 in /home/user/public_html/analytics/console on line 23
Parse error: syntax error, unexpected T_STRING in /home/user/public_html/analytics/console on line 23
Line 23 of that file is
Piwik\Translate::loadEnglishTranslation();
matthieu
(Matthieu Aubry)
June 12, 2014, 4:58am
2
it looks like your PHP CLI Is not running at least PHP 5.3
PLease check that your PHP CLI is using at least PHP 5.3.1 - ask your webhost if you have a question
pa1
July 8, 2014, 3:59pm
3
I’m having the exact same problem, and I am running Piwik 2.4.0 on PHP 5.4, though the PHP CLI is version 5.2.17.
Does this mean that the archiving is not working?
Since I’m on shared hosting, I don’t think I can use a different version of the PHP CLI. Any suggestions?
matthieu
(Matthieu Aubry)
July 11, 2014, 9:22am
4
Ask your web host how you can use newer version of PHP on the CLI, they should offer this option
pa1
July 11, 2014, 2:59pm
5
Thanks Matt, yes they do, and now it’s working perfectly.
