Hello, I’m archiving with the console command matomo_4_14_2/console core:archive --url=https://ma… but after the line “Starting Matomo reports archiving…” it doesn’t work. How can I check where it hangs . With the -vvv parameter, the line “Applying queued rearchiving…” appears and nothing more
INFO [2023-08-17 07:10:19] 2263005 ---------------------------
INFO [2023-08-17 07:10:19] 2263005 INIT
INFO [2023-08-17 07:10:19] 2263005 Running Matomo 4.14.2 as Super User
INFO [2023-08-17 07:10:19] 2263005 NOTES
INFO [2023-08-17 07:10:19] 2263005 - If you execute this script at least once per hour (or more often) in a crontab, you may disable 'Browser trigger archiving' in Matomo UI > Settings > General Settings.
INFO [2023-08-17 07:10:19] 2263005 See the doc at: https://matomo.org/docs/setup-auto-archiving/
INFO [2023-08-17 07:10:19] 2263005 - Async process archiving supported, using CliMulti.
INFO [2023-08-17 07:10:19] 2263005 - Reports for today will be processed at most every 3600 seconds. You can change this value in Matomo UI > Settings > General Settings.
INFO [2023-08-17 07:10:19] 2263005 - Archiving was last executed without error 85 Tage 13 Stunden ago.
INFO [2023-08-17 07:10:19] 2263005 - Continuing ongoing archiving run by pulling from shared idSite queue.
INFO [2023-08-17 07:10:19] 2263005 START
INFO [2023-08-17 07:10:19] 2263005 Starting Matomo reports archiving...
DEBUG [2023-08-17 07:10:19] 2263005 Applying queued rearchiving...
