Connection timed out
After DB cleanup I get the following error:
Exception: /var/www/html/core/Tracker.php(241): SQLSTATE[HY000] [2002] Connection timed out [Query: ?e_c=search&e_a=submit-ok&e_n=cid%3D3GIbTdD%2Fhit%20enter%2Fnone%2Fv&ca=1&idsite=1&rec=1&r=744575&h=14&m=35&s=33&url=https%3A%2F%[2Fwww.similarweb.com](http://2fwww.similarweb.com/)%2F&urlref=https%3A%2F%[2Fwww.similarweb.com](http://2fwww.similarweb.com/)%2Fwebsite%2Fvesaire.org%2F&_id=ce85051baced6376&_idn=0&_refts=0&send_image=0&pdf=1&qt=0&realp=0&wma=0&fla=0&java=0&ag=0&cookie=1&res=1536x864&dimension2=en-us&dimension3=false&dimension8=%7B%22sw_extention%22%3Afalse%7D&dimension9=%7B%22first_time_visitor%22%3Afalse%2C%22cookies%22%3A%22accepted%22%7D&dimension11=05fd5dd2-dd36-41ba-160b-afc61b33807b&dimension21=%7B%22section%22%3A%22home%22%7D&pv_id=0keHN4, CLI mode: 0]
Any idea what can I do to fix this?
Hi @bgadiel
What do you mean “After DB cleanup”?
there was a DNS issue.
please ignore.
