Hi guys, I have noticed that on a multi site installation I run there is a conflict between the WP Piwik plugin and the Gravity Forms plugin. With Piwik activated it doesn’t allow form editing in the admin side of the Gravity Forms plugin but when it is deactivated the Gravity Forms plugin works just fine.
I have the same config running on a normal Wordpress install and it doesn’t cause issues so it seems the issue is just relates to WP Piwik plugin and Multi Site wordpress installations.
