trying to ‘run the command ./console vue:build ExampleVue’.
gives an error
Can you provide the output of node -v and npm -v? If your node version is < 16, can you update to 16?
Someone on our team had the same issue, the fix for them was to:
Then vue:build started working again.
thanks will try this its currently v10
