Can I use
_paq.push('getAttributionInfo')
or sim to get attribution info from the _paq API?
Can I use
I think the best way to call a JS method is like this
_paq.push([function () {
var attributionInfo = this.getAttributionInfo();
console.info(attributionInfo)
Thank you! How do you know this.getAttributionInfo()
works? Couldn’t find it in the docs about _paq
You can find getAttributionInfo
in the JS-tracking-client docs:
https://developer.matomo.org/api-reference/tracking-javascript#configuration-of-the-tracker-object
But I agree that this website needs a better search (which is already partly build)
Oh! So using this
in _paq
gets access to the JS API? Good to know. ^^
You could also use Piwik.getAsyncTracker().getAttributionInfo()
, but it has one large disadvantage, which is solved by the _paq
syntax:
Matomo loads asynchronous, so it is possible that your code runs before the piwik.js has even finished loading and would fail therefor. If you use _paq
the function will be saved and run once Matomo has finished loading.
Right now I use setTimeout
to wait until Piwik is done. Is there another way, like, register a callback function instead?
I think what I posted above should be about what you need:
console.info("Matomo has finished loading")
