Pak_Kriss
(Pak Kriss)
October 30, 2019, 4:17am
1
Using the Bundled Tracker is an good idea.
Under Variables -> Cross Domain Linking is enabled.
Question is now where to add the domain(s) which I want to use for Cross Domain Linking?
Or do I need to push a event like How do I accurately measure the same visitor across multiple domain names (cross domain linking)? FAQ - Analytics Platform - Matomo ?
Under Tags -> Custom Url -> “Optionally, specify a custom URL which should be tracked instead of the current location.” is stating “instead” and talk about 1 url only (which is not a domain).
Please advise.
peterbo
(Peterbo)
October 30, 2019, 1:13pm
2
CrossDomainLinking uses the Domains setting above the send Beacon setting.
Pak_Kriss
(Pak Kriss)
October 31, 2019, 2:03am
4
Since it is not clear how the input string should look like, I just send the following js after OnLoad:
_paq.push(["setDomains", ["*.domain1.asia", "*.domain2.net", "*.domain3.id"]]);
_paq.push(["enableCrossDomainLinking"]);
Osel_Lim
(Osel Lim)
March 5, 2020, 10:54am
5
If I were to use Matomo Tag Manager and use “_mtm.push”, How do I use this _paq.push([“enableCrossDomainLinking”]);
