Hello!
How can I adjust the bounce rate? For example, so that the bounce rate is taken into account only if the site visitor leaves after 3 minutes?
I’m grateful if anyone can give me a clue to this mystery.
Hello!
I don’t understand clearly your needs:
If the user leaves after 2 minutes, do you want the visit is counted as bounced?
If the user leaves after 4 minutes, do you want the visit is counted as bounced?
I want that if you leave the state after 2 minutes the bounce rate is not counted and if after 3 minutes then count as plus one bounce rate
The bounce is the fact the visitor just flew over your site… Then it is strange to count a bounce when the user stays longer…
do you want the visit being counted before 3 minutes?
Yes, I want the visit being counted before 3 minutes
I don’t see any solution for this…
Maybe @innocraft has an idea?
Thank you so match!
@VIk4 The bounce rate is not changeable, however if you would like to identify the users who stayed on your website or bounced after a certain time, you can use segmentation to part those users. Please refer the following guide: https://matomo.org/guide/reporting-tools/segmentation/
Caveat, a visitor who only sees one page of your site, will have a visit time of 0 seconds until you add a heartbeat timer as described here:
