So i am wondering if anyone have any tips or tricks for me.
I would like to split out traffic by Country to be able to view “Swedish” data and “UK” data separate like the consent of “Views” in Google Analytics 3.
However as the timezone is set per domain i am wondering what the best “hack” is for this?
My brain goes to creating a domain per country local but that seams a bit “messy” and so i am wondering if anyone have found a good way to get around this?
Thanks
Hi @pete_swe
Solution 1
Create a segment for each country… Not so good ![]()
Solution 2
Use the Custom report, and set the visitor Country as 1st dimension
Solution 3
Extract your MySQL Data into a BI tool. For example:
