Hi, after the release log importer, I am trying to automate the new domain creation for the domains I host.
I started to create the tool from scratch to scan for .log files, create them in piwik interface if needed and assign them to a customer. Is there anything similar to this I could reuse?
The first part would be easily solved if --add-sites-new-hosts accepted the hostname parameter (because my logfiles dosn’t have it and can’t be modified)
More info about my issue on trac.
Log analytics list of improvements · Issue #3163 · matomo-org/matomo · GitHub
