Auto-Upgrade not possible?
When I log into Matomo, I see a “NEW UPDATE” note in the top of screen.
When I click update, and select automatic update, I get this error:
We’re sorry, but the action you were trying to perform failed due to a security check. This is a standard measure to ensure the safety and security of your account. Please try again, and if the issue persists, please contact our support team for further assistance.
I have tried logging out and in again; and tried different browsers.
I am on Matomo 5.1.2 and new version is 5.2.0.
How to fix?
Same problem with me.
Hi @Rurmeer , @EgonSnipes
You may perform manuall update bu:
  1. Unzip new Matomo version at the previous place of Matomo
  2. Update Database: ./path/to/matomo/console core:update
Thanks Philippe, that´s what I did.
Check the database table indexes and readd them if they are missing. All Matomo database tables should have at least a primary index.
If there are duplicates in the indexed columns (MySql/MariaDB):
  • Export all table data to a sql file (important!)
  • Truncate the table
  • add the indexes
  • replace “INSERT INTO” with “REPLACE INTO” in the sql file (this imports only the last duplicate row)
  • reimport the data
