Archiving undefined constant IPtoCompany FILTER_SANITIZE_MAGIC_QUOTES error
Hey, I got the following error while running the archiving.
INFO [2023-08-23 23:01:18] 2429 Scheduler: executing task Piwik\Plugins\IPtoCompany\Tasks.getListOfCompaniesThatVisitedWebsiteYesterday_1...
WARNING [2023-08-23 23:01:18] 2429 /var/www/html/plugins/IPtoCompany/UserSettings.php(48): Deprecated - Constant FILTER_SANITIZE_STRING is deprecated - Matomo 4.15.1 - Please report this message in the Matomo forums: https://forum.matomo.org (please do a search first as it might have been reported already)
Uncaught exception in /var/www/html/plugins/IPtoCompany/API.php line 294:
Undefined constant "Piwik\Plugins\IPtoCompany\FILTER_SANITIZE_MAGIC_QUOTES"
ERROR [2023-08-23 23:01:18] 2429 Uncaught exception: Error: Undefined constant "Piwik\Plugins\IPtoCompany\FILTER_SANITIZE_MAGIC_QUOTES" in /var/www/html/plugins/IPtoCompany/API.php:294
Stack trace:
#0 /var/www/html/plugins/IPtoCompany/API.php(190): Piwik\Plugins\IPtoCompany\API->insertCompanyDetails(Array)
#1 /var/www/html/plugins/IPtoCompany/API.php(84): Piwik\Plugins\IPtoCompany\API->getIPDetails('2a02:3038:60a::', Array, Array)
#2 [internal function]: Piwik\Plugins\IPtoCompany\API->getCompanies('1', 'day', 'yesterday', false, 200)
#3 /var/www/html/core/API/Proxy.php(244): call_user_func_array(Array, Array)
#4 /var/www/html/core/Context.php(28): Piwik\API\Proxy->Piwik\API\{closure}()
#5 /var/www/html/core/API/Proxy.php(335): Piwik\Context::executeWithQueryParameters(Array, Object(Closure))
#6 /var/www/html/core/API/Request.php(267): Piwik\API\Proxy->call('\\Piwik\\Plugins\\...', 'getCompanies', Array)
#7 /var/www/html/core/API/Request.php(560): Piwik\API\Request->process()
#8 /var/www/html/plugins/IPtoCompany/Tasks.php(46): Piwik\API\Request::processRequest('IPtoCompany.get...', Array)
#9 [internal function]: Piwik\Plugins\IPtoCompany\Tasks->getListOfCompaniesThatVisitedWebsiteYesterday(1)
#10 /var/www/html/core/Scheduler/Scheduler.php(309): call_user_func(Array, 1)
#11 /var/www/html/core/Scheduler/Scheduler.php(154): Piwik\Scheduler\Scheduler->executeTask(Object(Piwik\Scheduler\Task))
#12 /var/www/html/plugins/CoreAdminHome/API.php(75): Piwik\Scheduler\Scheduler->run()
#13 /var/www/html/core/CronArchive.php(659): Piwik\Plugins\CoreAdminHome\API->runScheduledTasks()
#14 /var/www/html/core/CronArchive.php(277): Piwik\CronArchive->runScheduledTasks()
#15 /var/www/html/core/Access.php(661): Piwik\CronArchive->Piwik\{closure}()
#16 /var/www/html/core/CronArchive.php(282): Piwik\Access::doAsSuperUser(Object(Closure))
#17 /var/www/html/plugins/CoreConsole/Commands/CoreArchiver.php(32): Piwik\CronArchive->main()
#18 /var/www/html/vendor/symfony/console/Symfony/Component/Console/Command/Command.php(257): Piwik\Plugins\CoreConsole\Commands\CoreArchiver->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#19 /var/www/html/vendor/symfony/console/Symfony/Component/Console/Application.php(874): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#20 /var/www/html/vendor/symfony/console/Symfony/Component/Console/Application.php(195): Symfony\Component\Console\Application->doRunCommand(Object(Piwik\Plugins\CoreConsole\Commands\CoreArchiver), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#21 /var/www/html/core/Console.php(108): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#22 [internal function]: Piwik\Console->originDoRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#23 /var/www/html/core/Console.php(147): call_user_func(Array, Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#24 /var/www/html/core/Access.php(670): Piwik\Console->Piwik\{closure}()
#25 /var/www/html/core/Console.php(148): Piwik\Access::doAsSuperUser(Object(Closure))
#26 /var/www/html/core/Console.php(87): Piwik\Console->doRunImpl(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#27 /var/www/html/vendor/symfony/console/Symfony/Component/Console/Application.php(126): Piwik\Console->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#28 /var/www/html/console(32): Symfony\Component\Console\Application->run()
#29 {main}
I can see it has something to do with the IPToCompany plugin. My version of it is v1.2.2
Instance:
Running in Docker
Matomo-Version: 4.15.1
MySQL-Version: 11.0.3-MariaDB-1:11.0.3+maria~ubu2204
PHP-Version: 8.1.22
No idea? My cronjob which is set to the first of the month failed again with this error:
WARNING [2023-08-31 22:00:04] 30614  /var/www/html/plugins/IPtoCompany/UserSettings.php(48): Deprecated - Constant FILTER_SANITIZE_STRING is deprecated - Matomo 4.15.1 - Please report this message in the Matomo forums: https://forum.matomo.org (please do a search first as it might have been reported already)
ERROR [2023-08-31 22:00:11] 30614  Uncaught exception: Error: Undefined constant "Piwik\Plugins\IPtoCompany\FILTER_SANITIZE_MAGIC_QUOTES" in /var/www/html/plugins/IPtoCompany/API.php:294
Stack trace:
#1 /var/www/html/plugins/IPtoCompany/API.php(84): Piwik\Plugins\IPtoCompany\API->getIPDetails('2a02:810b:4240:...', Array, Array)
#29 {main}
