Viper
March 4, 2014, 5:14pm
1
From archiving log
INIT
Querying Piwik API at: http://myhost/index.php
Running Piwik 2.1.0 as Super User: admin
ERROR: The Piwik URL http://myhost/index.php does not seem to be pointing to a Piwik server. Response was '/usr/bin/env: wrong key -- q
Try `/usr/bin/env --help' ...
Hi Viper,
which operating system and which PHP version are you using?
Viper
March 5, 2014, 9:29pm
3
Debian GNU/Linux 6.0.8 (squeeze) 64bit
PHP 5.3.3
BeRo
March 7, 2014, 10:16pm
4
I’ve the same issue after upgrading to 2.1.0 on Debian 7
matthieu
(Matthieu Aubry)
March 8, 2014, 6:19am
5
Ok let’s try to find out, replace in core/CliMulti.php the function at line 198 by this:
private function findPhpBinary()
$i = 0;
if (defined('PHP_BINARY')) {
var_dump(++$i . PHP_BINARY);
return PHP_BINARY;
$bin = '';
if (!empty($_SERVER['_']) && Common::isPhpCliMode()) {
$bin = $this->getPhpCommandIfValid($_SERVER['_']);
var_dump( ++$i . $bin);
if (empty($bin) && !empty($_SERVER['argv'][0]) && Common::isPhpCliMode()) {
$bin = $this->getPhpCommandIfValid($_SERVER['argv'][0]);
if (empty($bin)) {
$bin = shell_exec('which php');
if (empty($bin)) {
$bin = shell_exec('which php5');
if (!empty($bin)) {
return trim($bin);
Then, run the archiver script, what do you see in output?
