The topic of my post is if I follow all these steps, I mean first to check without specifying @columns then with it and then again without. As a result of the first step the data returns, in next steps - it doesn’t. The error appears in case of the un-changed date.
So if I ever include @columns in the request, it will never return data even if the @columns is not specified.
UPD: I found out that if only the @columns parameter has been entered incorrectly, the data wasn’t return in future requests with the same data range.
UPD 2: New screen shots with logge_message enabled. Please, see attached.
[attachment 400 01.jpg][attachment 401 02.jpg][attachment 402 03.jpg]
As you can see, if I made a mistake in @columns parameter, then I’m not able to retrieve data.
