I’m running Marino in a docker and have it setup successfully with MariaDB however it won’t launch due to something wrong with the Apache server. Any ideas?
[38;5;6mmatomo [38;5;5m21:53:01.96 [0m
[38;5;6mmatomo [38;5;5m21:53:01.97 [0m[1mWelcome to the Bitnami matomo container[0m
[38;5;6mmatomo [38;5;5m21:53:01.97 [0mSubscribe to project updates by watching [1mhttps://github.com/bitnami/bitnami-docker-matomo[0m
[38;5;6mmatomo [38;5;5m21:53:01.97 [0mSubmit issues and feature requests at [1mhttps://github.com/bitnami/bitnami-docker-matomo/issues[0m
[38;5;6mmatomo [38;5;5m21:53:01.98 [0m[38;5;2mINFO [0m ==> ** Starting Matomo setup **
[38;5;6mmatomo [38;5;5m21:53:02.05 [0m[38;5;2mINFO [0m ==> Configuring PHP options
[38;5;6mmatomo [38;5;5m21:53:02.05 [0m[38;5;2mINFO [0m ==> Setting PHP memory_limit option
[38;5;6mmatomo [38;5;5m21:53:02.09 [0m[38;5;2mINFO [0m ==> Validating settings in MYSQL_CLIENT_* env vars
[38;5;6mmatomo [38;5;5m21:53:02.22 [0m[38;5;2mINFO [0m ==> Persisted Matomo installation detected
[38;5;6mmatomo [38;5;5m21:53:02.22 [0m[38;5;2mINFO [0m ==> Updating default plugins in persisted data
[38;5;6mmatomo [38;5;5m21:53:10.68 [0m[38;5;2mINFO [0m ==> Restoring Matomo installation
[38;5;6mmatomo [38;5;5m21:53:11.31 [0m[38;5;2mINFO [0m ==> Trying to connect to the database server
[38;5;6mmatomo [38;5;5m21:53:11.40 [0m[38;5;2mINFO [0m ==> Launching schema update
Everything is already up to date.
[38;5;6mmatomo [38;5;5m21:53:12.99 [0m[38;5;3mWARN [0m ==> Skipping cron configuration for Matomo because of running as a non-root user
[38;5;6mmatomo [38;5;5m21:53:12.99 [0m[38;5;2mINFO [0m ==> ** Matomo setup finished! **
[38;5;6mmatomo [38;5;5m21:53:13.01 [0m[38;5;3mWARN [0m ==> Cron will not be started because of running as a non-root user
[38;5;6mmatomo [38;5;5m21:53:13.02 [0m[38;5;2mINFO [0m ==> ** Starting Apache **
[Thu Feb 04 21:53:13.120161 2021] [ssl:warn] [pid 1] AH01909: www.example.com:8443:0 server certificate does NOT include an ID which matches the server name
[Thu Feb 04 21:53:13.120671 2021] [ssl:warn] [pid 1] AH01909: www.example.com:8443:0 server certificate does NOT include an ID which matches the server name
[Thu Feb 04 21:53:13.155464 2021] [ssl:warn] [pid 1] AH01909: www.example.com:8443:0 server certificate does NOT include an ID which matches the server name
[Thu Feb 04 21:53:13.155859 2021] [ssl:warn] [pid 1] AH01909: www.example.com:8443:0 server certificate does NOT include an ID which matches the server name
[Thu Feb 04 21:53:13.174031 2021] [mpm_prefork:notice] [pid 1] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.1.1d PHP/7.3.27 configured – resuming normal operations
[Thu Feb 04 21:53:13.174068 2021] [core:notice] [pid 1] AH00094: Command line: ‘/opt/bitnami/apache/bin/httpd -f /opt/bitnami/apache/conf/httpd.conf -D FOREGROUND’
200.200.1.101 - - [04/Feb/2021:21:53:20 +0000] “\x16\x03\x01\x02” 400 226
200.200.1.101 - - [04/Feb/2021:21:58:31 +0000] “\x16\x03\x01\x02” 400 226
200.200.1.101 - - [04/Feb/2021:22:34:15 +0000] “\x16\x03\x01\x02” 400 226
