"Anonymize past data" not working
I started an “Anonymize past data process” and it hast the status “in progress” since 6 days!
See the tooltip text below.
I want to update to version 3.51 and I am wondering if I should wait until the process is done?
Can it take that long or hast it just got stuck? Maybe because PHP max execution time is not enough?
Scheduled date: 2018-05-25 14:45:19. Job Start Date: 2018-05-25 15:17:44. Current Output: Running behaviour on all sites.
Applying this to visits between '2015-12-01 00:00:00' and '2018-05-06 23:59:59'.
Starting to anonymize visit information.
This shouldn’t happen. Can you please create a github issue with a bit more details about your system (e.g. are you using cron?)?
I also try the anonymize past data option in matomo and i got same result the job is stuck. It’s been more then 10 days and nothing happen.
I got Matomo 3.5.1 on rhel 6.8
Did someone find a solution to this ?
Regards,
Stephane
Same problem here and we are on Matomo 3.7.0.
We tried using the “Command line” and also manually from the Matomo backend.
Any solution ?
Regards,
Cédric
