Hi I need to track android app. Is there any Sdk available for this otherwise how can i track android app in piwik. please point me to any good tutorial
If your app is developed natively in Java you can use the Java tracking API: github.com/piwik/piwik-java-tracking
If you use PhoneGap or something similar you need the HTTP tracking API: Tracking HTTP API: API Reference - Matomo Analytics (formerly Piwik Analytics) - Developer Docs - v3
We track the Android SDK feature request in: Release a Android SDK for Piwik - Mobile App Analytics · Issue #4733 · matomo-org/matomo · GitHub
+1 for the android SDK as we switched recently on Piwik
Hello Everyone,
We have started working on the Android SDK for Piwik… and we need your help!
If you can help us with testing & reviewing the code, please write in this issue: Testing the Android SDK for Piwik · Issue #1 · matomo-org/piwik-sdk-android · GitHub
Thanks,
