This is similar to : https://forum.matomo.org/t/import-logs-py-extend-the-list-of-file-extensions-to-track-as-downloads/10395
I’d like .whl
and .asc
to be added to the list of static downloads. Can they be added to the list? For context if necessary, I’m tracking downloads from a private PyPi server.
Additionally, is there an accepted way to add extensions at a per-instance level? I’m fine with changing the list in import_logs.py, but I’m not sure if there is anything else in the code base which needs to be tweaked.
As an example, GoAccess allows specifying static file extensions with
--static-file=<extension>
Add static file extension. e.g.: .mp3 .
Extensions are case sensitive.
