Here we speak about update to 1.8, then all this point seam be correct (because it worked before).
[quote=NHLfan]
Do you have the GeoIP plugin active?
I had the same problem since 1.8.1
I’ve solved it, by disableing the GeoIP plugin.[/quote]
Same here, nos stat after updating to 1.8.2… After deactivating the GeoIP-plugin, PIWIK works again.
Folks,
I don´t have GEO IP, but my visits has been going down, so far I haven´t found the issue …
I´ve tried to downgrade piwik javascript to version 1.5.1 because this version used to work very well but in vain .
[quote=matt]
There are 2 problems discussed in this tread
returning visitors not working well — please report your issue in this thread instead: 301 Moved Permanently
no visit since Piwik 1.8 ---- see this FAQ: Troubleshooting - Analytics Platform - Matomo
Hi ramilani12,
you have problem Nr 1 (es decir menos visitantes de retorno) not Nr. 2 (no counts). This is discussed here:301 Moved Permanently
