Wrong country for 177.249.0.0
HI,
177.249.0.0 is listed as USA. but 177.249.0.0 is Mexico.
80.187.0.0 is listed as USA as well, but it is Germany
36.110.0.0 is listed as USA, but actually it is China
How to fix it ?
Thanks,
Michel
Check your Geolocation settings, and check if you are using geoip2 and if you are using the latest version.
Also keep in mind that the free maxmind databases aren’t as precise as the paid one and you seem to be anonymizing the ip addresses, so the anonymized ip doesn’t have to be in the same country as the real one.
