Hello all, I am using CMSMS on my site - which is an open source Content Management System. As thus, inserting the javascript tracking code causes conflicts with the CMS so I had to make it an external .js file and linked to it in the template. However, 24 hours have passed and my data is blank - it’s not showing any visitors.
It could…depends on what you put in the .js file.
Perhaps it would make more sense to fix the conflict with your CMS.
I don´t know CMSMS, but it has a template system and it should be possible to put the code somewhere without conflicts.
Have you asked about Piwik implementation in a CMSMS forum?
The .js file isn’t working. I still have no stats. Apparently inserting it into the vbulletin style editor in the footer template causes an error warning as well.
I will ask on CMSMS forums about it. Does anybody have any experience using this with vbulletin?
For CMSMS (and Smarty), you have to wrap the Piwik tracking code within {literal} … {/literal} tags.
This comes from:
wiki.cmsmadesimple.org/index.php/FAQ/Introduction#Using_.7B.7D_characters_in_your_pages
Yes, that does seem to work. I got no error and the javascript code shows up when I view source.
Any ideas as to why it’s not working on vBulletin?
Yes, that doesn’t give any errors. The site seems to be tracking visits now. The forums should too. Thanks for all your help.
