I’ve swapped the domain to say example.com. Does anyone know why this isn’t working? Flash player is up to date in all browsers, and I have a crossdomain.xml file installed on the external domain.
The above code works in FF, Chrome and Safari (I’ve yet to test in Opera)
Thanks - sorry for the delay in replying to you. I’ve taken your advice, and lowered the security settings to accept all cookies - and turned off everything which could be blocking things… Alas, flash still fails to load.
IE 6 through to 8 fail. IE9 and all other browsers are ok. I am taking the code “as is” from the piwik api widget page.
When embedding as an iframe - this works… when embedding as flash, it doesn’t work. Really starting to pull my hair out on this one…
