I can’t install Piwik via the Web Platform Installer (it’s not visible, and clickign the link on the blog post doesn’t work). It would be great if someone could look into this.
Also, I have done a port of the Java server side tracking code for .NET
The source is at GitHub - mcintyre321/PiwikTrackerSharp
The Nuget download is at NuGet Gallery
| PiwikTrackerSharp 1.1.6
matthieu
(Matthieu Aubry)
September 22, 2012, 8:44pm
2
MS: thanks for the report, not sure why Microsoft removed us from there…
Java: thanks for your contrib. What is the difference with this contrib and the existing Java tracker in: PiwikTracker.java sync with PHP tracker and release 1.0 · Issue #3151 · matomo-org/matomo · GitHub ?
this is a version for .net (c#,Vb.net ,f#) conferred from the Java client
vipsoft
(vipsoft)
September 23, 2012, 4:03pm
4
Earlier versions of the Piwik package aren’t installable on their Web Matrix platform. (A limitation in their regex parsing IIUC.)
1.8.3 was submitted a while ago but its status still shows as “Testing”
You can install packages from Index of /WebAppGallery if IIRC but it’s been a while since I messed around with WPI.
