The problem isn’t magic_quotes_gpc neither the PHP version 5.3.28 that I use. I have tested it and changing to PHP version 5.4 for a short time doesn’t help either.
I can’t use the command line and cron jobs on the hosting server but it wasn’t necessary before.
As I wrote before the configuration of magic_quotes_gpc doesn’t solve the problem.
The following error appears with PHP 5.4 (without the possibility for magic_quotes_gpc):
INFO [2014-05-05 15:52:25] [4dba8] ---------------------------
INFO [2014-05-05 15:52:25] [4dba8] INIT
INFO [2014-05-05 15:52:25] [4dba8] Piwik is installed at: http://domain.tld/piwik/index.php
INFO [2014-05-05 15:52:25] [4dba8] Running Piwik 2.2.0 as Super User
INFO Piwik\CronArchiveFatalException[2014-05-05 15:52:33] [4dba8] ERROR: The Piwik URL http://domain.tld/piwik/index.php does not seem to be pointing to a Piwik server. Response was ‘Content-type: text/html
INFO [2014-05-05 15:52:25] [e981a] ---------------------------
Then if you still have the problem (which should be the case), could you email me matt@piwik.org your server information (SSH) so I can connect + reproduce the issue on your server? This would be really helpful! thanks
