Hi guys,
I’ve installed Piwik 0.2.35 on our hosted company webserver. The installation worked without any errors and the dashboard displayed (without data of course).
After adding the script into our template and accessing the webpage to generate some data, I receive now the error messages you see in the attached image:
Warning: gzuncompress() [function.gzuncompress]: data error in /webhome/bfa.ch/www/stats/core/Archive/Single.php on line 250
Backtrace →
#0 Piwik_ErrorHandler(2, gzuncompress() [function.gzuncompress]: data error, /webhome/bfa.ch/www/stats/Archive/Single.php, 250, Array ([name] => Referers_searchEngineByKeyword,[typeValue] => blob,[table] => piwik_archive_blob_2009_05,[db] => Zend_Db_Adapter_Pdo_Mysql Object ( => mysql, => Array (), => 2, => Zend_Db_Profiler Object ( => Array (), => , => , => ), => PDO Object (), => 0, => 1),[value] => xœK´2´ªÎ´Ò5´ö³®�Ä)) called at [(null):0]
#1 gzuncompress(xœK´2´ªÎ´Ò5´ö³®�Ä) called at [/webhome/bfa.ch/www/stats/core/Archive/Single.php:250]
I need to mention that our website is built with Silverstripe 2.3.1.
I’ve also did a web- and forumsearch but the only thing I found was the following old bug: http://dev.piwik.org/trac/ticket/203 but that ticket was closed 5 months ago.
Anyone of you guys has any idea where the problem is?
Thanks in advance,
Stefan
Screenshot:
[attachment=44:piwik_error.jpg]
