This is an update to the .htaccess example file originally posted by me in 301 Moved Permanently above. I’m deliberately positing the update in a new post, instead of just updating the original one (where I’m going to add a reference to the new post), so that file comparison (copy and paste in the tool of your choice) can be used to easily see the changes introduced.
I did NOT incorporate any other .htaccess rule proposals below my original post – I’ll leave it to the user, if desired. Partly due to my incompetence.
The goal of this update was simplification (which I promised earlier) of the “Advanced server protection – paths and files” part at the end of the original .htaccess file, as Piwik (unlike Joomla) does not use, nor require, SEO. While on it, I also found two bugs, which might have been responsible for some of the “it doesn’t work for me” comments after my original post. I apologize for the inconvenience caused:
Lines 108 and 110 of the original post: A backslash between “GLOBALS(=|” and “_REQUEST(=|”, and the following “[“ got somehow lost on the file submission. (I guess it was filtered out by the post submission system - see comment after the code below.) I’ll compare the posted end result to my local copy this time, to make sure that nothing gets lost this time.
Line 154 of the original post: The “L” flag was missing in “[R=301,L]”. This is a real bug of mine – the “L” flag is needed, even though the comment above that line (removed in the new version) claims the opposite. The bug didn’t show itself on my setup until I started adding the optimizations I did at the end of the file.
While at it, I’m also reviewing and updating the post comments before and after the code. So, here comes the complete rewrite of the original post:
Here is another example of securing your Piwik installation, based on Joomla .htaccess example under htaccess examples (security) - Joomla! Documentation, modified and adapted to Piwik. Please refer to that for additional information, if needed. The file is being used on a free shared web hoster (i.e. php.ini, etc., is not modifiable).
It does not use user or IP authentication (which could be done additionally as shown in posts above, if desired).
The assumed Piwik installation address is www.test.example.com/piwik/, with the www.test.example.com domain used exclusively for the only one Piwik installation, and the below .htaccess file placed into its main directory (i.e. above the /piwik/ directory). Although, I suggest using a different directory name and use of the “/js” tracking subdirectory of Piwik (instead of “piwik.js”) as described in “README” in the “js/” directory of your Piwik installation, to not have the “piwik” string anywhere in the URL. Because privacy tools, such as some AdblockPlus filter lists, have started blocking content from URLs containing that string anywhere in the URL.
## .htaccess example implementation, last tested with Piwik 1.11.1
## Based on version 2.5 (proposed) of May 16th, 2011 (proposed 2.5.5 wiki doc
## history verstion by G1smd of May 17th, 2011) Joomla .haccess file
## example under http://docs.joomla.org/Htaccess_examples_%28security%29
########## Begin - RewriteEngine enabled
RewriteEngine On
########## End - RewriteEngine enabled
########## Begin - RewriteBase
# Uncomment following line if your webserver's URL
# is not directly related to physical file paths.
# Update Your Joomla! Directory (just / for root)
#RewriteBase /
########## End - RewriteBase
########## Begin - No directory listings
## Note: +FollowSymlinks may cause problems and you might have to remove it
IndexIgnore *
Options +FollowSymLinks All -Indexes
########## End - No directory listings
########## Begin - File execution order, by Komra.de
DirectoryIndex index.php index.html
########## End - File execution order
########## Begin - ETag Optimization
## This rule will create an ETag for files based only on the modification
## timestamp and their size. This works wonders if you are using rsync'ed
## servers, where the inode number of identical files differs.
## Note: It may cause problems on your server and you may need to remove it
FileETag MTime Size
########## End - ETag Optimization
# Beginning of additional settings by jawsmith (from the
# "htaccess.txt" provided with Joomla, and Joomla
# security forums)
# Code taken from "Other useful settings" of http://docs.joomla.org/Htaccess_examples_(security)
ServerSignature Off
# Disable all methods except GET and POST, as only those are needed
# (Note: TRACE does not seem to be possible to disable in .htaccess, only in server config by the host)
RewriteCond %{REQUEST_METHOD} !^(GET|POST) [NC]
# Return 405 Method Not Allowed
RewriteRule .* - [R=405,L]
RewriteCond %{THE_REQUEST} (\\r|\\n|%0A|%0D) [NC,OR]
RewriteCond %{HTTP_REFERER} (<|>|’|%0A|%0D|%27|%3C|%3E|%00) [NC,OR]
RewriteCond %{HTTP_COOKIE} (<|>|’|%0A|%0D|%27|%3C|%3E|%00) [NC,OR]
RewriteCond %{REQUEST_URI} ^/(,|;|:|<|>|”>|”<|/|\\\.\.\\).{0,9999} [NC,OR]
# Note: User agents blocking not taken over, as agent names could easily be changed, and e.g. Nikto is used by me as well on http://www.hackertarget.com/website-scan
#Block mySQL injects
RewriteCond %{QUERY_STRING} (;|<|>|’|”|\)|%0A|%0D|%22|%27|%3C|%3E|%00).*(/\*|union|select|insert|cast|set|declare|drop|update|md5|benchmark) [NC,OR]
RewriteCond %{QUERY_STRING} \.\./\.\. [OR]
RewriteCond %{QUERY_STRING} (localhost|loopback|127\.0\.0\.1) [NC,OR]
# Comment by jawsmith: commented following out, as otherwise error by the world map widget (flash)
#RewriteCond %{QUERY_STRING} \.[a-z0-9] [NC,OR]
RewriteCond %{QUERY_STRING} (<|>|’|%0A|%0D|%27|%3C|%3E|%00) [NC]
# Note: The final RewriteCond must NOT use the [OR] flag.
# Return 403 Forbidden
RewriteRule .* - [F]
# Note: Protecting .htaccess and other files explicitly is not necessary - they will be implicitly protected by the access lockdown at the end of the file
# End of additional settings by jawsmith
########## Begin - Rewrite rules to block out some common exploits
## If you experience problems on your site block out the operations listed below
## This attempts to block the most common type of exploit `attempts` to Joomla!
# If the request query string contains /proc/self/environ (by SigSiu.net)
RewriteCond %{QUERY_STRING} proc/self/environ [OR]
# Block out any script trying to set a mosConfig value through the URL
# (these attacks wouldn't work w/out Joomla! 1.5's Legacy Mode plugin)
RewriteCond %{QUERY_STRING} mosConfig_[a-zA-Z_]{1,21}(=|\%3D) [OR]
# Block out any script trying to base64_encode or base64_decode data within the URL
RewriteCond %{QUERY_STRING} base64_(en|de)code[^(]*\([^)]*\) [OR]
## IMPORTANT: If the above line throws an HTTP 500 error, replace it with these 2 lines:
# RewriteCond %{QUERY_STRING} base64_encode\(.*\) [OR]
# RewriteCond %{QUERY_STRING} base64_decode\(.*\) [OR]
# Block out any script that includes a <script> tag in URL
RewriteCond %{QUERY_STRING} (<|%3C)([^s]*s)+cript.*(>|%3E) [NC,OR]
# Block out any script trying to set a PHP GLOBALS variable via URL
RewriteCond %{QUERY_STRING} GLOBALS(=|\[|\%[0-9A-Z]{0,2}) [OR]
# Block out any script trying to modify a _REQUEST variable via URL
RewriteCond %{QUERY_STRING} _REQUEST(=|\[|\%[0-9A-Z]{0,2})
########## End - Rewrite rules to block out some common exploits
########## Begin - File injection protection, by SigSiu.net
RewriteCond %{REQUEST_METHOD} GET
RewriteCond %{QUERY_STRING} [a-zA-Z0-9_]=http:// [OR]
RewriteCond %{QUERY_STRING} [a-zA-Z0-9_]=(\.\.//?)+ [OR]
RewriteCond %{QUERY_STRING} [a-zA-Z0-9_]=/([a-z0-9_.]//?)+ [NC]
########## End - File injection protection
########## Begin - Advanced server protection - query strings, referrer and config
# Advanced server protection, version 3.2 - May 2011
# by Nicholas K. Dionysopoulos
## Disallow PHP Easter Eggs (can be used in fingerprinting attacks to determine
## your PHP version). See http://www.0php.com/php_easter_egg.php and
## http://osvdb.org/12184 for more information
RewriteCond %{QUERY_STRING} \=PHP[0-9a-f]{8}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{12} [NC]
## SQLi first line of defense, thanks to Radek Suski (SigSiu.net) @
## http://www.sigsiu.net/presentations/fortifying_your_joomla_website.html
## May cause problems on legitimate requests
RewriteCond %{QUERY_STRING} concat[^\(]*\( [NC,OR]
RewriteCond %{QUERY_STRING} union([^s]*s)+elect [NC,OR]
RewriteCond %{QUERY_STRING} union([^a]*a)+ll([^s]*s)+elect [NC]
########## End - Advanced server protection - query strings, referrer and config
# Added by jawsmith: sub-domain prevention and www requirement (redirect with code 301 ("moved permanently")
# in the same rule
# Notes: 1. If you want to do it separately, or use https, refer to Joomla reference htaccess implementation
# 2. This needs to be done before the below file protection exceptions,
# so that the redirect occurs before the exceptions are accessed.
# 3. Replace test.example.com with your own domain
RewriteCond %{HTTP_HOST} !^www\.test\.example\.com$
RewriteRule ^(.*)$ http://www.test.example.com/$1 [R=301,L]
########## Begin - Advanced server protection rules exceptions ####
## These are sample exceptions to the Advanced Server Protection 3.1
## rule set further down this file.
## Allow robots exclusion file
RewriteRule ^robots\.txt$ - [L]
########## End - Advanced server protection rules exceptions ####
########## Begin - Advanced server protection - paths and files
## Allow Piwik API files or plain directories
RewriteRule ^piwik(/(index\.php|piwik\.(php|js))?)?$ - [L]
RewriteRule ^piwik/js(/(index\.php|piwik\.js)?)?$ - [L]
## Allow limited access for certain Piwik system directories with client-accessible content
RewriteRule ^piwik/(libs|plugins|themes)/([^/]+/)*([^/.]+\.)+(jp(e?g|2)?|png|gif|bmp|css|js|swf|html?|pdf|svg|ico)$ - [L]
## Disallow access to all other (works, as only resources explicitly allowed above are accessed, no SEO pseudo directories)
########## End - Advanced server protection - paths and files
[b]CAUTION: As described in the bug number 1 before the code above, a backslash between “GLOBALS(=|” and “_REQUEST(=|”, and the following “[“ gets lost on the file submission on lines 99 and 101 of the above code. I.e., correct as follows, by replacing the “BACKSLASH” string with a “\”:
- Line 99: RewriteCond %{QUERY_STRING} GLOBALS(=|BACKSLASH[|%[0-9A-Z]{0,2}) [OR]
- Line 101: RewriteCond %{QUERY_STRING} _REQUEST(=|BACKSLASH[|%[0-9A-Z]{0,2})[/b]
What I am not able to test, is the “one-click update”, which I cannot use due to global restrictions of my free shared hosting provider. (The server is not allowed to fetch anything from anywhere, among other things.) I always have to do the update via FTP. (By just creating a “diff” of a new Piwik version and uploading only that.)
If the above .htaccess example doesn’t work for you after you updated it for your needs as described in its comments (e.g. the Piwik installation URL), you will need to find out which rule(s)/condition(s) (it may be several) break it for you, and disable them (see also comment lines for possible alternatives). To do that, start disabling (i.e. commenting out) the rules/conditions successively, and testing, until the problem disappears. Then, start successively re-enabling the ones before the problematic one, and testing, until you either re-enable them all, or find other rule(s)/condition(s) causing problems. For information on meaning of the RewriteRule flags (F, L, R, NC, OR, etc.), see RewriteRule Flags - Apache HTTP Server Version 2.2.
Additional hint: As with any other web application, unless you use https AND your server TLS is super up-to-date AND your client is up-to-date and secure, try to log-in to your Piwik installation with administrator rights as little as possible. Simply create an additional account restricted to “viewing” and use it when no administration work is required. And: same applies if the above “unless” condition is met, as we all know that a piece of software stays secure forever.
