Hello, our Users Flow is coming up empty regardless of range or segment. We have used the plugin on some other sites, but all are currently deactivated. Any ideas?
The plugin would require you to invalidate previous data for this to appear, data since the plugin was added should be available. Are you seeing data on this site now?
Yes, thank you. Issue is resolved
